rvman69's avatar
rvman69
Dometic fridge RM2652 tripping thermal sensor
Hello all, my Dometic RM2652 in my 99 Travelmaster class C RV was in my level shop hooked up and running good. I went out one day after we had a pretty bad storm and our electricity went off and back on about 5 times in a short period of time. Then it stayed off for about 36 hours. I noticed that our fridge power light was not on the fridge. So I turned the fridge off and reset the thermal switch on the heat unit. I went back in and turned fridge on. The power came on and the auto light was on. So I thought well the storm just threw the thermal sensor. So I turned the fridge off so I could clean it thinking it was fine. Well today I went out to turn the fridge on to get ready to go camping at the end of the month. When I turned it on the the lights came on the control panel as it should. It was on for a while then later I noticed the lights on the fridge were off. I went back to the thermal sensor and it was thrown again. I reset it again and it did the same thing. The heating element is getting hot. I do not think the cooling unit is bad but not positive. I do not see any yellow or green looking stuff around the heat unit. Is there anything else I should check that could be making the fridge not operate correctly? Could it be that the thermal sensor switch is just bad? Would appreciate any help. Is there a way to post pictures on here? I was going to post a couple so you could see there seems to be no yellow or green looking stuff. Thanks
