Old-Biscuit
Aug 04, 2019Explorer III
P3 connector
Pin 1 ---White Wire----GROUND
Pin 2 ---Yellow Wire---12V DC+ to gas valve solenoid AND reignitor controller
Pin 3 ----empty
Pin 4 ---Blue Wire---TEST Port (used to test that circuit board is sending DC Voltage to gas valve/reigniter
Dino Board
THREE different boards
Check which Dometic Board you have then pick the right Dino
Dino boards for RM2652
Pin 3 ----empty
Dino Board
