Dometic Refrigerator No Power
revickers
I think I know what I did. When I was washing my RV, I accidently sprayed water in the refrigerator vent. When we got to our next campsite, I turned the refrigerator on, everything seemed fine, but then about 15 minutes later, the power went out. I checked the fuses - 3 and 5 amp and they were OK. But when I checked the 15 amp, it was blown. I replaced it thinking I solved the problem. Well, it still did not work. I checked the 15 amp again and it was OK but still no power. No lights, fan, no electricity at all to the refrigerator. Could it be the board, how do I know. I am now going to replace the 3 and 5 amp, even though they are OK. Any other suggestions?
Thanks,
Reggie
3 REPLIES 3
Old-Biscuit
DO you have any panel lights?
No panel lights........NO DC power going to fridge
Do you have a 'recall kit'........high temp sensor installed on burner stack?
If it trips it shuts down ALL DC to fridge.
It has a manual reset button.....could have gotten wet.
3A fuse on circuit board is for the DC circuits
5A fuse is for the 120V AC electric element only
1492
Moderator
Moderator
Moved from Forum Technical Support
darsben1
GFI IN TRAILER POPPED?
SOmetimes 3 or 4 outlets are covered by on e gfi
Traveling with my best friend, my wife in a 1990 Southwind
