Walaby
Jul 06, 2017Explorer II
Dometic RM1350 Fridge Problem with High Temp switch
Having a problem with the high temp switch on my Dometic RM1350 in my TT. The high temp switch trips every time I am on the move and running on propane. When Im stationary, running on electic, works fine for days. I ran it for 2+ hours on propane, no problem. But, when Im pulling, it trips and shuts down the whole fridge. I can reset it, and as long as Im not pulling, it will keep running. Next time I stop, it's tripped again.
The switch Im talking about is the one mounted on the chimney stack on the burner. Believe that is the high temp switch, at least according to what I've read.
Going to call Dometic tomorrow, but thought I'd check here and see if anyone else had a similar issue. Wondering if it's just a weak switch.
Mike
Mike
