Follow the 12VDC+ (RED Wires)
At Terminal Block (item K)
To Thermal Fuse (item Y....near burner)
To Thermofuse (item U...switch on burner stack)
To J4 terminal on Circuit Board
Check that the 12VDC- (Black Wire)
from Terminal Block to Ground is clean and tight
IF you have 12VDC+ at J4 Terminal then check the 3A fuse...far left...is good (test for 12VDC on both sides of fuse...not just look at it
Wiring DiagramAs for that Dino P-711
Did your Original board part number start with '385' OR '293'??
Not a correct replacement for Black Box '385' boards
