smiledr's avatar
smiledr
Electrical issues
2015 Itasca Navion 24G Woke up this morning and half of the outlets don’t work and neither does the TV. The micro works and all the lights work. I found a gfi in the bath and in basement storage that I reset. I reset circuit breakers. Reset breaker at shore power hook up. Still nothing. The outlets in the bath and kitchen work but not bedroom or near sofa and TV doesn’t work. What am I missing?
  • GFI can be a problem. Years ago I had one that would not reset because of small water leak.
  • Fixed it. I reset the gfi for the third time. Thanks for the help
  • wa8yxm's avatar
    wa8yxm
    True story: man came to me with a very nice high end Motor home and the exact same issue you have.
    I ask him if he had an inverter (he did not know) well let's look
    First door he opened was batteries
    next was the inverter
    Flipped the breaker from Tripped/off to back on and said 'Go check'
    He went in and his wife ask "Does he think he can help"
    Husband answered "he's already fixed it"
    Suggest you check for an inverter
    Breakers may be on inverter (his were very easily found sometimes they are in back) may be flip type may be push in to reset.
    May also be a 2nd breaker box somewhere (That's my rig)
  • Is there a GFCI in the outside outlet to plug things into when under the awning? Maybe that one is tripped.
  • Tighten connections in the breaker box. Outlets are daisy chained using those cheap self contained devices, perhaps you have a bad connection there. If you can find an outlet that will still works, but can be switched off with the breaker, start there. Also, pull GFCI that controls that circuit and check it.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
