Electrical Wire Identification
rdhetrick
Hi all,
Trying to help my dad identify some wiring in his coach for a project. Manufacturer hasn't been any help so I thought I'd try here.
He has two wires that we are trying to identify the wire size. Seems the obvious method would be to use a set of calipers, but he doesn't have any.
Anyway, there are two stranded copper wires, each with different markings. Anyone recognize the markings or format?
Wire 1: "150 FA Ground"
Wire 2: "603c GLY LPS"
I've not been able to find anything.
Thanks in advance!
Rob - Solo Full Timer
2017 Winnebago Travato 59G
Former 2006 Mandalay 40E
15 REPLIES 15
CA_Traveler
dougrainer wrote:
I can gurantee that the Norcold 12 volt supply line is NOT 10 gauge. Since the 12 volt for your year Model Norcold is just for operating the refer electronic controls, odds are the supply gauge is 16/14 gauge. But, it will NOT be larger than 14 gauge. Doug
That's the bottom line - Bad install on Dad's refer. Correct the wiring and move on, sure he could go back to the installer...
Makes one what else is not correct, insulation, air clearance, support, etc.
2014 Grand Cherokee Overland
Bob
Roger10378
Sounds like a good possibility.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
CA_Traveler
I wondered if GLY could be Galley.
Bob
Roger10378
They look like factory circuit numbers. Circuit 150 is a factory ground. Circuit 603 is some kind of lamps circuit(I haven't figured out the GLY abbreviation).
2005 Cardinal 30TS
dougrainer
CA_Traveler
Seems like the wrong approach to me. Send him to the store and buy an cheap digital voltmeter. Measure the voltage at the refer with the comperssor running, no shore power and battery partially discharged. If it meets mfg specs then wiring is OK. Next repeat but measure at the battery terminals to make sure batteries are OK. Better yet have the batteries load tested. What did he find?
Otherwise measure the distance for new wires and use a wiring calculator to find the wire ga needed for the new wires. And go directly from the refer to the battery with a fuse unless there is some really heavy wire nearby that can be used.
Bob
Bobbo
wa8yxm wrote:
For smaller an adjustable wrench (The one that made crescent famous)
I always thought the rolls made crescent famous.
Bobbo and Lin
enblethen
I checked my wiring diagrams for my rig. They use a different coding.
Factory refer is more likely around 16 gauge.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
rdhetrick
OP here, to make a short story long...
Dad's coach is a 07 or 08 Fleetwood Bounder Diesel.
He recently had the 12v JC Refrigeration compressor unit installed and has had several problems with it. I've been helping him troubleshoot the problems.
The latest problem could possibly be a result of excessive voltage drop in the 12v supply to the JC unit. The JC unit is supplied with a connector that plugs directly into the 12v supply wires to the original Norcold unit after the Norcold is unplugged. They also state that the 12v supply wires should be minimum 10 gage. I have doubts that the original factory wiring to the Norcold was 10 gage, thus the question about the markings.
Lwiddis
As said..always go bigger on any manufacturerโ€™s wire size you are replacing.
MEXICOWANDERER
Image next to a fingernail?
wa8yxm
The wire markings idetify the wire's FUNCTION not the size but the purpose.
Beyond that I can not help.. For BIG I"m tlaking battery size big. a ruler might help
Then measure the gap in the jaws or take it (Tape over the adjuster) to the store with you.
NOTE if you are trying to add to or replace a 18 ga wire and all you have is 16 or 14. NO PROBLEM. the other way around PROBLEM You can always "Go big"
enblethen
OP: Please post make and model of your dad's coach
Bud
USAF Retired
Pace Arrow
opnspaces
Navigator II
Navigator II
Are the markings printed on the wire as if from the wire manufacturer? Or is he talking about printed labels that were possibly installed by the coach manufacturer? I only ask because a 1/0 wire is a big wire which I find hard to believe is in a factory built RV.
