doc_brown
Jul 04, 2014Explorer
If in auto mode it will shut off as soon as the parameter selected has been met. For example if the temp mode is off it will go on if your battery charge is less than 12.2V. If charge is fine and temp mode is on it will shut off if hotter inside than set parameter or cooler than cold parameter.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
