stlucia0127's avatar
stlucia0127
Entry step not working
2015 Class A Thor Hurricane -- went to move it in the driveway, opened door, entry step extended properly. Moved it, stepped out, closed the door, and entry step retracted but not all the way. Now it won't move at all, motor doesn't come on, light underneath doesn't come on, but I can wiggle the steps somewhat. Can't find a fuse, all batteries are good. Suggestions?
Thanks!!
1 Reply
  • It has a 20AMP fuse. If you have a Inverter look in the compartment it is located in for a fuse box.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 18, 2026
