arielle101's avatar
arielle101
excessive undercarriage noise in 2014 Jayco White Hawk 23MBH
We were wondering if anyone has experienced an excessive amount of undercarriage noise in a new trailer. Our Jayco, purchased two weeks ago, makes loud metal-on-metal cracking noises when backing up. The dealership initially told us it was the sway bars, but it continued when positioning the trailer without the sway bars, and it was clear that the noise was coming from the axle assembly.
We have had two previous trailers (Jayco) with only mild clicking noises from the brakes, etc. This new one is really, really loud. It's hard to imagine backing into a campground site at night with this thing banging and cracking.
The dealer has now lubricated the area, which helps a bit, and has told us that the noise is caused by the wide stance of the axles and that it will settle down in time. In the meantime, the trailer soounds like it's self-destructing whenever we move it backwards.
It doesn't seem right to us - has anyone else had this problem?
Thank you in advance.
  • Thank you for the suggestion. We are taking it out this weekend for the first time. If the problem hasn't improved, we will have them look into this possiblity.
  • Lots of trailers creak. If your noise is excessive, I would wonder about what torque was use to install the springs to the hangers. If some clown put a heavy-duty air gun on the nuts and pulled them down too tight the suspension will make noise because of binding.
  • It's interesting that another new trailer with the same configuration doesn't make the noise.
    The trailer is brand new, so it's not worn shackles, but the noise is coming from the shackles, according to the dealership, and this will "wear off" after some use. To us, metal grinding on metal can never be a good thing.
    We're going to have to take it out again and see if the lubrication has helped. It's frustrating because we have to take the dealerships word for it at this point. Noise is subjective - to us, the amount of noise it's making is unacceptable; to the dealer, it's normal. I guess we will be in touch with Jayco if it continues. Hate to have to go down that road with a new trailer.
    Thank you for the replies.
  • Is it a new unit or used? If used you might check the spring shackles, they may be worn out.
  • My Crossroads has wide stance axles but never made a lot of noise
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
