theoldwizard1
Mar 13, 2022Explorer II
Crawl under near the tank. Have someone cycle the key from OFF to ON (not start). You should be able to hear the fuel pump run for about 10 seconds.
Sometime in the 1990s (?), most manufacturers (Ford for sure) started adding a fuel pump control module. These are usually near the tank. They are known to fail.
