Gary45
Mar 17, 2022Explorer
211Racing wrote:Gary45 wrote:
My E350 based motorhome has a lift pump in the tank and a fuel pump mounted on the frame just behind the front wheel. If yours the same check electrical connection.
That's very interesting. I replaced the fuel filter just behind/below the driver's seat. Didn't see a pump. What year is yours? I assume you mean the left front wheel? I'm not seeing that set-up for a 2002.
Mine is a 1986 , the gas supply is set up like fuel injection even though it has a carburetor, there is a pressure relief valve near the carburetor so constant flow through return to tank.
The pump is mounted on the frame below drivers seat.
I read somewhere it was done that way because in a motorhome the gas tank is farther back, also with the constant flow through the lines less chance of vapor lock.
