GaryS1953's avatar
Apr 07, 2018
Exterior 12 volt outlet
Hi Everyone- I want to install a 12 volt outlet on the exterior of our camper. I would like just a single port with a bracket to mount on the underside of the 5th wheel overhang, so it needs to be weatherproof. The ones I’ve found so far seem relatively low amperage. I will connect it directly to the battery and shunt with appropriate fusing. I’m going to be using it to power a 12 volt inflater for bike tires and an inflatable kayak and so on. Can anyone recommend an appropriate outlet? Thanks!
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
