TheJim's avatar
TheJim
External Propane Tank
We used to have a Class A coach and we had the extend-a-stay type adapter to use an external propane tank, so I am well aware of how that works. We have now moved to a Class B and there is an issue with the onboard LP tank not filling. It will take ordering a new tank to fix that problem. In the meantime, we would like to use the van. The onboard tank is well hidden under the van with a remote fill, so not possible/easy to use the extend-a-stay approach. There is an external quick-connect fitting for attaching a grill. So, I am thinking about hauling around a 5 gallon LP tank that I would set out and attach to the van when camping. It seems that I could use a regulator and attach this to the grill quick-connect. However, I do not know if there are any one-way valves that would prevent this and I do not know what it would do when it hit the "wrong side" of the regulator. Any experience or thoughts appreciated.
  • Yes, I could do that. Are the any other pitfalls if I do that?
  • Thanks much. That is a bummer, it sounded so easy. There is a cutoff between the van and the onboard tank but I believe it is before the regulator (coming from the onboard tank side) so that would not help. So, I guess I am off to plan B, whatever that is.
  • wa8yxm's avatar
    wa8yxm
    The Grill connect is a low pressure device DO NOT back feed propane into that fitting as the regulator will vent.
    True story
    My Class A would not fill
    Turns out when he pulled the hose out of the cabinet to hook up to the tank he snagged the emergency shut off cable on the Pump system...
    To fix. Shove ECO lever back to normal. Yup. really happned .
    Took them a while to figure it out however and I found a lower cost propane supplier in the mean time.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
