ajriding's avatar
ajriding
Aug 28, 2019
Fantastic Fan Quit
My fan quit working. I tested and I still have 12 volts going to the fan.
I removed the fan assembly (not the lid) and bumped the wires on a battery and the fan started right up.
The fan is 12 volts at 25 watts, so can't be drawing many amps, 2.
I can't figure the problem.
Could the fan be bad, still work, but be drawing many amps more than the wiring could handle? but then it should blow a fuse (15 or 20).
Other ideas?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
