waynefi's avatar
waynefi
First time charging new batteries
I just bought a pair of Costco/Interstate 6 volt batteries. On the first two charges, they don't seem to be accepting charge as fast as I expected. They have not gone above 31 amps either time.
I am using a VEC1093DBD. On my old batteries (a pair of group 24 Marine/RVs), I saw the current hold at 40 amps for some time with slowly rising voltage, then taper to 10 amps in about a half hour, and continue tapering.
On my second charge of the new ones, it started at 31 amps at 15.1 volts, started tapering immediately, tapered to 10 amps in an hour and a half, and slowly droped to 5.2 amps at 15.4 volts after 5 hours. Temperature is about 40F.
The first charge was even stranger. The batteries each read 6.22 volts when I got them. On the charger, the current started at 16 amps, dropped to 11 after 5 minutes, and then wandered between 8 and 12 amps for two and a half hours before I cut it off. Then I discharged them to 12.3 volts open circuit, and started the second charge.
Is this a break-in effect of new batteries, or is there something really wrong?
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 24, 2025
