Sep-27-2019 03:41 PM
Sep-28-2019 09:43 AM
Cummins12V98 wrote:
Eternabond is meant to make a long term seal with no maintenance required. Adding Dicor to the edge IMHO adds another maintenance item. Simply a waste or time.
Sep-28-2019 09:23 AM
Sep-28-2019 08:05 AM
Sep-28-2019 07:03 AM
MURPHY55347 wrote:
Wow is this stuff sticky! Once it touches anything it is stuck for good. When doing a long seam make sure you get the tape started straight. When pulling off the backing to expose the adhesive make sure to pull it off straight. I tried pulling it off at an angle and the backing tore at a 45 degree angle so now I had a piece that only half stuck. That was not fun trying to fix. Prepped the area with acetone and that worked well. Using a razor blade to cut the tape works best. Rolled with a plastic wall paper roller and that worked good. I know some people here like to follow up with a dab of Doctor at the edges but I see no reason to.
Sep-27-2019 10:01 PM
Sep-27-2019 06:12 PM
Sep-27-2019 05:58 PM
Sep-27-2019 05:57 PM
Sep-27-2019 05:49 PM
Sep-27-2019 05:21 PM
Sep-27-2019 03:54 PM
