Freezer to cold
mdock2
Any ideas as to why the freezer would start getting so cold that the food inside bags have started icing up. Have cut it down as low as possible without causing refrigerator from getting to warm.....Have been in cool weather for the past month in the northeast....
thanks
Marty (KI4NAI)& Shirley
1998,38' DutchStar F/L Cat
MEMBERSHIPS
FMCA
Bits & Bytes,
Elks International (Webmaster)
FCCC
PPA (Life Member)
Moose
ARRL-ARES
National Park Travelers Club
Visited 158 National Parks
Places we've slept since 2007
19 REPLIES 19
Old-Biscuit
Kiwi_too wrote:
TXiceman wrote:
Frost in the freezer bags does not mean the freezer is too cold. That is simply moisture from the food that had frozen.
Ken
X2
X3
Air in storage bags has moisture and it will ice up
A faulty or fallen down thermistor (temp sensor in food section) would cause items (milk, eggs, vegetables etc.) in food section to freeze.
Also you being in cold area refrigerator is more efficient at changing ammonia coolant state (liquid to vapor to liquid) so it stays a lot cooler.
AllegroD
Ken
X2
j-d
If it has a Thermistor to input temp info to the logic board... A poor or unplugged connection will cause the board to command full cooling. A "failed open" thermistor also will.
darsben
The temperature sensing device may have become dislodged. Some are mounted to the fins in the back of the fridge part.
Traveling with my best friend my wife!
TXiceman
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
