cekkk
Jul 15, 2015Explorer
Fresh Water/Pump questions
Haven't used my onboard water in this TT, only once in the other one.
I want to sanitize the water system. I'm adding water now, maybe 15 gallons so far. half cup Clorox is in.
No leaks inside. WH bypass is open so it can fill.
Do I need to seal the hose that is used to prime the pump for winterizing? It's open on the end and sucks air when pump turned on
but not water coming from faucets. May not have had enough water in tank when I turned it on.
No water is coming out of low point drains.
Right now I am just wanting water to pour when I turn pump on and open a faucet.
Any suggestions? thanks.
