Bear with me as I am on the phone in the bush Dometic RM1350SLMX 2 years old Doesn’t cool on electric Control says it’s on. No error message There is power at the plug. Anything I can check pas...
There is a fuse on the rear Refer control board. If that fuse is GOOD, check for 120 between the 2- 120 element wires. If those wires have 120, then the Heat Element is bad. There is NO indication or error for 120 failure on Dometic refers. You need to switch to Manual LP. Doug
