1985 Chevy 454 external fuel pump 7 to 10 pounds psi after sitting for 30 minutes fuel cannot be sucked out of a tank to brand new fuel pumps I'm stopped I am a mobile mechanic in myself what do I do ...
Have you tried opening the fuel tank cap? This is an issue that is not uncommon with that period GM vehicles. There was a problem with the purge canister valving.
Note, If you include some breaks and punctuation, it makes it much easier to read. Even if you are working form a small device, breaks alone can help to separate the thoughts.
Matt
