ace5179
Feb 11, 2018Explorer
Furrion camera FOS48TA-BL no power to camera voltage help
We purchased a new 2018 Coleman Lantern TT. It comes pre-wired and housing unit for a Furrion camera. I successfully paired the camera with the monitor; however, when I plug the camera into the pigtail at the back of the trailer there is no power. The blue led light does not come on. I checked everything possible including taking the marker light off and checking the connection to the light. I also used another pigtail and again no power.
Is it possible there is not enough voltage to power the camera? The marker lights are incandescent bulbs.
Thank you
Did you read the FTS "Announcement : READ BEFORE POSTING HERE"?
Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
questions. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
Admin
RV.net
Thank you
Admin
RV.net
