landyacht318
Oct 29, 2018Explorer
How is your house battery grounded?
Since you are asking it to take power from engine battery to recharge, then all the current for house battery, engine battery and likely all the stock vehicle loads is now on the original alternator to engine battery cable, which was not intended to carry all this current.
You might consider either upgrading this OEM cable, or adding another thick parallel circuit from alternator + to engine battery, fused of course.
I prefer taking juice for house battery right from alternator (+) output stud rather than from engine battery.
If you are relying on the frame ground, well the original engine to battery ground is also going to have to carry the extra current of a depleted lifeline battrey, a large depleted lifeline AGM, which can suck up EVERYthing your alternator can make, especially the voltage regulator, which controls alternator output, is seeking 14.2v+. I recommend if you are using a frame ground, to add another ground from frame to an alternator bracket mounting bolt, and take extra steps to insure these remain low resistance and tight.
I would recommend not idling parked to recharge, as underhood airflow is quite limited when not moving, and a hot alternator is not a happy alternator, and it will get quite hot feeding a depleted lifeline 8d.
Also keep in mind your ford's voltage regulation is not always going to be asking for 14.2 to 14.4v, as lifeline wants when anything but 100% charged.
Lifeline wants your 8d battery to get no less than 51 amps when depleted to 50%, and you should not expect your alternator to meet this at idle, or perhaps at speed if your headlamps and blower motor are on.
Deeply cycled AGMS will get tickled to death by too light of charging currents, a bunch of low and slow solar, even to full every day, pisses them off. Your solar will barely do 20 amps in ideal conditions.
Its an expensive battery, you might want to ensure that it gets that 51+ amps from 50% SOC when you have grid power available and that you can hold it at 14.2 to 14.4v until amps taper to 1.275amps.
If you cannot properly feed that lifeline AGM, then do not expect it to live up to its venerable reputation.
A voltmeter on your dashboard revealing the Lifeline voltage. is wise, even though it will likely be dissappointing and ignorance is bliss until it is time to buy a new battery.
I have a hall effect sensor ammeter whose display is on my dashboard so i can see what my battery is accepting from the alternator when driving. Wonderful tool. The more amps the battery is accepting the lower its state of charge.
