j-d
Nov 04, 2016Explorer II
irollman wrote:
OK, so does "replacing", which I'm inclined to do, involve cutting off the old one, leaving enough of a "flange" to glue the new one on?
NO NO NO NO
The flanges are a one-time install. The valve is sandwiched between those flanges and sealed with a square cross section O-Ring on each side. Little bolts hold the sandwich together. New valve comes with new bolts/nuts and the O-Rings.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
