imadtchmn
Nov 04, 2014Explorer
Bobbo wrote:naturist wrote:
No, the computations are pretty simple. 50+30+30=110 amps. At 120 volts, that would be 120 x 110
= 13200 watts, so yes, a 15,000 watt generator would cover you.
I agree with the earlier posts that the 50 amp rig is 2 legs of 50 amps each, so the math is
(50+50) + 30 + 30=160amps = 19,200 watts.
You can get a generator smaller than 20,000 watts continuous duty, but remember that you won't be able to run all 3 RVs at full capacity at once. Few 50 amp RVs run at full capacity, but many 30 amp RVs do, or nearly so.
I always thought the 50 amp service was two 30 amp legs and two grounds, not two 50 amp legs. I've lost my mind and still trying to find it.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
