Geo Method question
_en_Plain_Air_
I have wanted to try the Geo method for the Black Tank. The instructions I have found on line say to dissolve water softener and detergent in hot water and put in black tank. I heated on the stove top water with water softener pellets and laundry detergent until it was dissolved, then let the mix cool down. As the mix cooled, the sides of the pan developed a pretty thick 'build-up' of film that I think would obstruct the holding tank sensors, thereby defeating the purpose. Thinking the soap was the problem, I tried dissolving just the water softener pellets and waiting for it to cool down. gain, the heavy build-up on the sides of the coolpot. Neither solution felt 'slipery' like very soft water, as I would have expected based on the description of this method. I have NOT dumped any mix into the holding tank. For those of you with experience in Geo method, is this your experience? Are the water softener pellets (dissolved) the right water softener? Thoughts? Thanks!
20 REPLIES 20
Michael_Fisher
I wonder if maybe a lot of people are just over-thinking this; what we have been doing for more than 2 years is simply dropping Tide laundry pods into the black and gray holding tank; It has been been working just fine as far as cleaning and draining; for any odors we'd had in the past, we just drop in a Snuggles brand freshener pod into each tank- we have no odors and our gauges are reading a lot more accurate...
lanerd
nickthehunter wrote:
Just go to Walmart and buy black tank chemical in a bottle and be done with it. No mixing, no mess, no fuss.
If you do a little research here on this forum, you'll find that:
Black tank chemical in a bottle does nothing but mask the odor if (or when) you have a malfunctioning system and the odor of the black tank seeps into the rv. It does not clean the tank of residue left over after draining, it does not promote any type of resistance to future residue and will not do anything more than what plain old water will do.
The laundry detergent used with several gallons of water during traveling will indeed wash out the inside of the tank and insure all solids will be flushed out during draining. The water softener has two fold results. First it will soften the solids making it easer to drain and secondly, it will coat the inside of the tank making it slippery so that solids and tp won't stick to it.
Black tank chemicals are just waste (no pun intended) of $$.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
lane_hog
Black tank chemical is snake oil....
We use liquid fabric softener instead of powdered softener. Same effects, makes the tank walls nice and slickery.
  • 2019 Grand Design 29TBS (had a Winnebago and 3x Jayco owner)
  • 2016 F-150 3.5L MaxTow (had Ram 2500 CTD, Dodge Durango)
  • 130W solar and 2005 Honda EU2000i twins that just won't quit
nickthehunter
Nomad II
Nomad II
AllegroD
Use the liquids and do away with the heating process.
lanerd
Gonzo42 wrote:
I use the liquid Calgon which I get cheaply from Wally World. I order on line and pick up at the store. Very inexpensive. Plus I use powdered laundry detergent with very good results. YMMV.
If you use liquid Calgon, why don't you use liquid laundry detergent also? I personally use liquid Oxy-Clean along with the liquid Calgon.
Note to others who use different brands of water softener..... please note that not all water softeners are the same and will not have the same results. No need to go cheap, the price difference isn't that much and you can be assured that using the correct water softener will provide you with the results you're looking for.
Ron
Ron & Sandie
TPMS: Pressure Pro
Bend
OP-
If you are headed to colder climates, add 1/2 gal. of cheap RV antifreeze or a cup of your rock salt to the mix.
Harvard
There are 2 types of tank sensors;
1. The type that are not reliable are spot sensors that are screws that protrude through the side of the tank that rely on conductive current between sensors. These sensors tend to snag stuff and such!
2. The type that are more reliable are "capacitive" sensors that are two conductive aluminum strips that are located on the OUTSIDE of the tank wall. These capacitive sensors are less prone to problems when compared to type 1 sensors. IMO.
brirene
'en Plain Air' wrote:
...hoping our tank sensors will...read more accurately.
Don't hold your breath on that. Sensors are notoriously inaccurate no matter the efforts you use to clean them. You'll get a sense of how long you can go before filling the tanks, and recognize the signs that they are getting full. Good luck!
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
Gonzo42
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
_en_Plain_Air_
OP here. Thank you all so much for your input. I'll get the right products and give it a whirl. I'm hoping our tank sensors will stay cleaner and read more accurately.
ktmrfs
water softener pellets are pure sodium cloride, TABLE SALT NOT water softener. water softener such as calgon is completely different chemical that acts something like what a water softener does.
AGAIN you do NOT want to use water softener pellets.
2011 Keystone Outback 295RE
MudChucker
those water softening pellets you used are salt for water softeners. you want to buy the calgon water softener product or something similar.
calgon softener on amazon
we do similar and also use a basin to wash dishes and the soapy water gets dumped down the toilet to help fill up between dumps.
2017 Cougar
2015 Ram 3500 Megacab 6.7 Cummins Aisin transmission
brirene
Charles Bruni's Geo Method page. I do it once a year or so.
