Gonzo42 wrote:
I use the liquid Calgon which I get cheaply from Wally World. I order on line and pick up at the store. Very inexpensive. Plus I use powdered laundry detergent with very good results. YMMV.
If you use liquid Calgon, why don't you use liquid laundry detergent also? I personally use liquid Oxy-Clean along with the liquid Calgon.
Note to others who use different brands of water softener..... please note that not all water softeners are the same and will not have the same results. No need to go cheap, the price difference isn't that much and you can be assured that using the correct water softener will provide you with the results you're looking for.
Ron
