CA_Traveler
Dec 21, 2020Explorer III
Understood but don't discount changing conditions. Turn off all CBs except the one for the Gen circuit. Do you still have the problem?
GFCI tripping can be difficult to isolate. A ground fault from the hot line to ground is one and turning off CBs can help to isolate that type.
GFCIs can also detect on a turned off circuit a potential leak from neutral to ground. Isolation of this fault involves disconnecting the circuits neutral wire.
Refers involve moisture and are another possible source.
