TBammer's avatar
TBammer
GFCI Issue looking for a solution
My camper has a 15 amp GFCI circuit that starts in the bathroom and has 4 other outlets downstream on the load side. While out camping recently I had issues with the GFCI refusing to reset when the camper was plugged into the post and we were on shore power. I would hit the reset button and it would just trip again. I bought a new GFCI outlet and same problem. I thought it was a problem with one of the downstream outlets.
I figure when I'm home I'll start isolating the outlets one by one to find the culprit. At home, and with the help of an adapter on the cord, I plug into an isolated 15 amp circuit (don't have a 30 amp circuit) off my house panel. And this point I think, just for the heck of it, try to reset the outlet, and lo and behold it resets. I am not doing anymore investigation into other outlets for now.
The only thing I can think is that the voltage at the campground was low. Would that cause a GFCI not to reset? Is one of those Progressive EMS surge protectors the answer? How hard a wiring job is the onboard style?
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 24, 2025
