Road Trip Time wrote:
I recently purchased a 1995 Ford e350 with a 1996 Dutchman Class C Camper on it. I discovered the gray holding tank leaking. It appears like the camper will have to be lifted off the frame to remove the tank. Any thought or possibly a link to a decent youtube video.
Thank in advance
John
Have you priced what that tank is going to cost?
I had a blow out on one of my first Class C's that went into my sewage bay and shattered the black and gray tank bay and fittings. I called for an estimate for the replacement tank and found it is all one piece tank and bay. At the time it was well over a couple of thousand dollars. It was for a 1997 four winds Class C.
It was replaceable and NO they do not lift up your chassis.
There are so many good epoxy glues that can be used on so many types of plastic now. I would call you local RV dealership parts department and ask what they use to patch RV tanks.
Have you actually located the hole in the tank? Because when they leak it can come from the screws on the blades and the leak looks like it's coming from the tank.
