liborko wrote:
dougrainer:
Natural gas is not pure metane and what is called LPG is not pure propane but a mixture of different gases with propane and butane predominant gases. The ratio of propane and butane in LPG varies with season and location same as vapor pressure of gasoline varies with season and location. The ratio of propane and butane in LPG is only known to a supplier and even the people who dispense the LPG don't know it. This may explain why my furnace worked better on Canadian propane(LPG) posssibly because it has higher content of propane and lower content of butane.
LPG gas
When I carried propane (the mix you defined), the shipment was loaded--propane on the first 90-95% of cargo and a cap of the last 5-10% of Butane. This was because Butane was at a much lower temp and would tend to keep the total product at a lower temp. The lab folks took care of the calculations. The propane was loaded at Hess Oil in Houston, TX and was carried to as far as Ecuador but mostly in the Caribbean. Canadian Propane may have a lower % of Butane, all of ours South of the 49th is blended to a certifiable BTU content (but, of course, it's not all the same, practically).
