grodnay's avatar
grodnay
HELP! 1991 Ford E350 Jamboree transmission fail
Hi all
When I pulled into the Las Vegas KOA I noticed that transmission fluid is dripping badly from the front part of the transmission. There was also a squeaking noise that I noticed since about 20 miles before. It was a hot noon.
I understand that the front seal has failed. I made a service call and was offered to replace the transmission for $1000 + cost of the transmission. The guy suggested that there was no point in replacing the seal only. He said that if the seal has came loose, probably the shaft that comes form the transmission is loose, and the new seal will fail soon. Also, he says that as the transmission fluid is burned, so parts of the transmission are varnished and the transmission will fail.
It was shifting normally, and as far as I can say, the fluid does not smell burned. Also, I had it checked a couple of thousand miles ago and the fluid was in good condition.
Should i replace the complete transmission? Someone had any luck with replacing the seal only? Is this a known problem?
Any recommended transmission workshop in vegas?
$1000 fair price?
Your urgent advise is appreciated,
-Guy
