avmenard
Jun 21, 2023Explorer
Help with Onan 5000 starts won’t stay running.
Hello, I have a 1998 Georgieboy Pursuit with an Onan 5000 generator in it. The generator will start and run while holding the start button but as soon as you let you the generator cuts off. We have changed the oil, oil filter, fuel pump and filter, and the plugs and wires but we are still getting the same thing. Any help would be appreciated. Also the generator will only crank if plugged in to shore power or rv motor is running.
