bigfootford
Sep 10, 2021Nomad II
1L243 wrote:bigfootford wrote:
Sure sounds like you have a restable breaker that is sometimes installed on rv's/campers. It is on the line from the Converter to the batteries. Your converter is putting out enough amps to trip the breaker..
Your solar for most installs bypasses that breaker, depends on how it was installed.
Jim
I replaced all the re settable breakers with manual ones a few months ago.
All is still working as it should. Im going to drain the system down to 80% again to make sure all is still good.
When you do this, using a dvm measure the voltage on the battery as the surge occurs.
If you see the voltage climb then drop there is the clue.
Jim
