Tom_M1
Jul 06, 2017Explorer
If the OP tried to make adjustments to slow the generator down to idle speed, that was his first mistake. A non-inverter generator has a governor that will try to maintain a constant speed, most likely 3600 rpm. When a load is applied, the governor will open the throttle to maintain 3600 rpm.
