- 1492ModeratorMoved from Forum Technical Support
- prowler17545Explorerthanks, that's simple enough !
- Old-BiscuitExplorer IIITurn OFF the 'electric' ON/OFF Switch and turn ON the 'gas' ON/OFF switch.
Provided the propane is valved in service and the water temperature is below water heater t-stat setting it should fire off.
If you have a Suburban water heater the electric ON/OFF switch is in outside compartment in a corner.....just a rocker switch.
Having RV issues? Connect with others who have been in your shoes.24,200 PostsLatest Activity: Feb 18, 2025
