Trackrig wrote:
Usually there are screws on the inside frame that screw through to the outside frame pulling the two together. Do you have screws on the outside screwing into the inside frame? They are usually about every 6 inches.
Bill
X 2...And if it is like my windows.
Just be careful with the window as it can fall out with "clamp ring" or "compression ring" removed and fall to the outside. RV windows cost plenty and usually have to be ordered. Doubtful it will fall as it should have some caulking which would prevent it from falling. But don't give it a chance. If you have or had a leak from around that area it might be weak. There might be some very little small barely visible numbers and letters at one of the corners. Write it down and hope you don't need it.
Then stick up whatever material your using as replacement and then go outside and trace the area of window and then it cut out.
Hope you more lucky than I was on getting replacement paneling the same color and texture.
Keep us posted
