ImaginaryNumber
May 07, 2016Explorer
How to replace/re-engineer leaking fresh water drains
The low point water system drains on my 2004 motorhome (R-Vision Trail Lite B+ 235S) have always been difficult to access and very finicky to seal tight. Their condition has now deteriorated to the point that neither will completely seal and my fresh water supply slowly and constantly drips through the drain valves. The drip accelerates to a significant spray when the water pump is turned on.
![](http://i.imgur.com/pKuFmLYl.jpg)
The current project is to replace the two leaking valves (tank drain valve and plumbing system drain valves) and possibly add an in-line water filter to the water tank mechanical space under the rear dinette seat. I would appreciate any guidance from fellow RVers who have experience with similar projects. Close-up images of each valve can be viewed by clicking the links below.
The original plumbing system drain appears to be a push-pull 3-way valve that I can't seem to find in any current parts catalog, and the water tank drain appears to be a more common metal angle shutoff valve. Unless advised otherwise, I plan on replacing these original parts with inexpensive valves that are more readily available.
Does anyone have ideas, suggestions, or guidance for this project?
