Jozanne's avatar
Jozanne
hydraulic fan motor seal keeps leaking
I have a 1992 Elite 250 CAT pusher, I inherited it from my dad and I have had (2) cooling system fan motor's replaced in 18 months. The seal keeps leaking. Gillig has sent one of the motors to me (new) and the other was from the manufacturer (who I have no idea who they are). Has anyone had the same problem with this type of side mount fan motor and does anyone know who the manufacturer is? ALSO could I change the system over to electric fan motors and has anyone done this?
  • Probably they have been sending you remanufactured motors. If the reman facility purchased a bad batch of seals or if someone was installing them improperly there could have been a whole run of them that leak.
    I would pull the motor and take to a local hydraulic rebuilder for inspection and a new seal.
    x2 on check the fan for imbalance.
  • If the blade is out of balance, then it can wobble, and cause the failures. You might consider changing the fan blade next time.
    How clean is your radiator and fan blade?
    You should be washing the radiator with plenty of simple green and a garden hose. Use a chemical sprayer to apply the diluted solution of Simple Green. Let it soak a while, and then spray off with a garden hose. Many times it is difficult to see the dirt in the radiator, and it will cause the engine to run warm, then the fan will kick into high speed more often, leading to more wear on the cooling fan.
    While electric fans seem like a 'great idea' your radiator needs a LOT of air flowing through it. My buddy with a 200 HP engine in his Econoline pickup tried electric fans for his 460" engine pickup. It did not work, and the engine overheated. That was a 7,000 pound pickup. While electric fans work great in a 3,500 pound car, and even some 8,000 pound pickups, they are not designed for anything over about 10,000 pounds. The electric fans are just to small.
    My buddy had one of JcWhitney's largest 16" diameter fans with a 3,000 CFM rating. It draws about 12 amps or 144 watts. Your hydraulic motor is probably rated at 3 - 8 horsepower, or about 3,000 - 8,000 watts capacity.
    Have fun camping!
    Fred.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
