I rewired my trailer with a square box, two fuses have incoming power. On from shore power and one from the inverter. I can not figure it out but each hot fuse only powers certain load fuses (no I d...
Breaker panels have two buss bars. They aren't connected. The are normally for L1 and L2 used with a 240v/120v 50 amp service. You seem to have 2 120 volt inputs: shore and inverter. You need a transfer switch.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
