time2roll
May 08, 2019Nomad
Two branch circuits? Get two transfer switches.
Transfer switch has two input, one output.
Remove the branch circuit from the breaker and panel (H,N,G) and attach to the switch output. Attach new romex from breaker to input 1 and the inverter to input 2 of the switch. Repeat for second transfer switch and you are good to go.
Check that the fridge and converter are not part of these branch circuits. If they are you need to move the converter to another branch or add a breaker to have on a separate circuit. For the fridge you can set to propane only or move same as the converter.
I have mine set up like this and it has been flawless. And yes power goes through the breaker.
https://www.donrowe.com/KISAE-TS15A-Automatic-Transfer-Switch-p/ts15a.htm
20 amp also available.
