CA_Traveler
May 26, 2019Explorer III
time2roll wrote:Also call Magnum and find out if you need a dual 30A CB on the Magnum input to protect the Magnum.
I believe if you feed the full 50 amp split phase through the inverter transfer switch the main breakers in the RV should be swapped down to 30 amps.
