opnspaces
Aug 07, 2019Navigator II
Is a neutral ground bond plug safe
This is just a curiosity question, I'm not getting shocked and I'm not planning on building a neutral ground plug.
I read on here about hot skin issues where a person is getting shocked by their RV and it's usually because the ground is broken somewhere in the shore power path.
I also read on here where people on generator need to create a neutral ground bond plug to trick their EMS into allowing power through.
The question then is does running a neutral ground plug cause a possible danger for a hot skin issue where the danger might not have existed without the plug?
