MrWizard
Nov 01, 2022Moderator
The check valve will be in the hot water output line at the back of the water heater,
In my case it was almost impossible to get at, because of the way the water heater was installed, ( outside below the basement ,inside its own welded box, which i had to cut open, working under the rv with my angle grinder)
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
