โSep-08-2021 11:25 AM
โSep-18-2021 09:46 AM
Rigdon wrote:I pressurized both cylinders through the spark plug hole with 100 psi. At TDC air just rushed out of the intake, rotated fly wheel to different positions and compression built up no air coming out of the tail pipe or intake was noted . I went back to TDC and poured Chemtool into each spark plug hole and reinserted plugs and will soak the valves for a couple of days. At TDC I did not see chem tool leak out. May leak oy slowly. I still don't know how intake valves can just stick in both cylinders at the same time while the engine was running? I can see them sticking if it sat for a period of time without the engine running. Has anyone seen this happening before?
if the intake valve had pressure coming out instead of in then you have stuck intake valves on both cylinders. the trick with pressurizing the cylinder through the sparkplug works very well. Other small engines used to get carbon fouling in the valve guides resulting in stuck valves and no compression usually from the carb running rich.
โSep-16-2021 05:27 PM
โSep-16-2021 02:58 PM
โSep-16-2021 07:17 AM
bgum wrote:If you are talking about the wire to the fuel shut off(anti dieseling solenoid) I have done that. Also removed the fuel shut off solenoid to see if the plunger comes down when the starter button is pushed and it does.
Try disconnecting the wire and start.
โSep-16-2021 06:40 AM
โSep-15-2021 07:58 AM
โSep-13-2021 10:34 AM
โSep-13-2021 10:19 AM
Bud
USAF Retired
Pace Arrow
โSep-13-2021 10:10 AM
enblethen wrote:No it is a Command M-20EP. Very hard to find info on this engine. What is a pulled exhaust?
It could be a pulled exhaust, rare!Our other discussion came up with CH20 engine, correct?
Kohler gaskets
โSep-13-2021 06:48 AM
Bud
USAF Retired
Pace Arrow
โSep-13-2021 06:29 AM
โSep-10-2021 12:34 PM
Bud
USAF Retired
Pace Arrow
โSep-10-2021 12:14 PM
enblethen wrote:Yes I know that would be the next step, it was raining all day yesterday and this morning I had a root canal done so hopefully get to it tomorrow.
I found a couple other manuals. They show overhead push rod type engine with gear driven camshaft off crankshaft.
I would pull easy to get to valve cover. Check to see if the valve rockers move.
โSep-10-2021 09:58 AM
Bud
USAF Retired
Pace Arrow
โSep-10-2021 09:46 AM
allbrandauto wrote:What I did is check the compression on my lawn mower and got 65 psi so I know the gauge is good. Yes is spins really fast and can feel a slight pressure when I put my finger over the spark plug hole. In addition when I remove the air cleaner I feel no suction on the intake, instead it blows air out of the intake.
how do you know the compression gauge is good when you crank it over with the plus in it does it sound like its cranking realy fast take a plug out and put your finger in the spark plug port and bump it over than you will know
