tvenetis's avatar
tvenetis
Koler Generator Problem
I am helping a friend on his Koler generator 4000 watt that came with his camper and I can get the engine to turn over and start with the switch on the panel by the engine but when I release the switch the ignition cuts out. I tried the switch on the dash and that switch does not work all the time and I tested the switch and it is fine. Also the choke is not heating up. I would appreciate any help thanks. Tim
