Clay_L
May 23, 2012Explorer
etmorrison wrote:
Help, my Kwikee series 32 wont extend so I can check the motor and gears. Is there a way to release the steps. I tried direct connecting a 12 battery on the Yellow and Red wires and reversing them just in case, but just sparks and clicking.
This puppy is retracted and tighter than a drum even with power off
There is a pin that holds the extending/retracting arm to the step. If you remove the hitch pin from the retaining pin and remove the retaining pin the steps can be manually extended or retracted.
