lj2654's avatar
lj2654
Kwikee Steps issue
I just returned home from a trip of 12 days. The last day we drove in the rain.
My kwikee steps have always worked correctly till now. They sometimes go up all the way but sometimes have to help them a bit. When they extend they come down all the way but the motor keeps running for a bout 4-5 seconds after they are fully extended. This is a new issue for me. Would it be the motor itself going bad? Or possibly the controller box?
  • A lot of the older ones were Ford power window motors Could try to match it at your local parts store.
  • garyemunson wrote:
    Motor is bad. Plastic gears inside are getting stripped/worn out. Easy repair and you'll be good for years.... Get the numbers off the motor (there are a few different ones) and look on eBay or Amazon.
    Hey Gary, going to pull the motor off today sometime, I think the part number has fallen off, guess I can try to match it up....?
    thanks Gary!
  • Motor is bad. Plastic gears inside are getting stripped/worn out. Easy repair and you'll be good for years.... Get the numbers off the motor (there are a few different ones) and look on eBay or Amazon.
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
