theoldwizard1's avatar
theoldwizard1
Nov 02, 2016
Laminated sides vs aluminum siding
Is there any unbiased data out there that shows laminated FRP/rigid foam/aluminum frame is better than aluminum siding, fiber glass insulation and wood studs. ?
My "gut" says the laminated side should be better, assuming they are designed and assembled properly, with adequate "studs", proper welding and proper lamination. The rigid foam board insulation should help prevent the wall from "racking".
But, I have heard horror stories about delamination. I guess that is one benefit for the "old fashioned" way. It is easier to repair.
