- CA_TravelerExplorer IIIAnother solution for the TV and sat receiver is a dedicated inverter connected to the batteries. No AC input and no AC switch over for this inverter. Hence no TV interruption due to AC changes. Your converter charges the batteries and supplies power for this inverter. This also keeps a dish from researching due to power interruptions if yours is that type.
cannesdo wrote:
Turning off the breaker will avoid any utility surges as it shuts down or comes back on. Not going to stop a close strike from jumping to the cord and RV.
What if I just flipped the switches off at the post during the big storms? Not the same as unplugging?- becronExplorerI'm like triker33 I bought $$$ surge protect an it is hard wired in to my breaker box so I don't have to worry about it walking off, An it can protect my rv where ever I plug in ,an it has been on 24-7 for almost 14 years.
- joebedfordNomad III switch mine off because it's a 400w cheapie. Works perfectly but why use a cheapie when it's not necessary. (I unplug shore power during electrical storms).
- cannesdoExplorerThanks for the input. Lots of good information. The power blinked off twice today (and no storms (ugh...this place is having problem). The inverter was on and the light blinked the first time and the 2nd time the tv went off for about 2 seconds then came right back on. I blew up my inverter years ago by running two heaters on high on the same circuit (it's sorted now) and I remember noticing my inverter was on and I think I always associated that with that event and it seemed wrong to keep it on when I was plugged in. I just turned it on when I wasn't plugged in and needed power. Glad I asked.
What if I just flipped the switches off at the post during the big storms? Not the same as unplugging? - wa8yxmExplorer III
cannesdo wrote:
It is ok to leave the inverter on during a thunderstorm in case the power goes out (it does often here) so that I don't have to deal with getting the dish to find the signal all over again? Is that harmful in any way?
I suspect millions of folks use a device called a UPS (Uninterruptible Power Supply) Now for a fact, most of them are not they are IPS-es (interruptible) but what are these things? Well they have 4 parts
Converter to charge the battery
Battery
Inverter in case of power fail
Changeover realy (The think that interrupts)
Some even have true UPS
Mains power---Converter---Battry---Inverter----Power out to load.
Yes, it is ok to leave the inverter on full time. In fact that is exactly what I do.. Not only that...
I have a second converter (ORiginal) on this RV.. I've been in places wher the power was a bit... iffy.. So I shut off the 30 amp breaker to the inverter, thus forcing it to supply the loads it powers, like TV and Microwave.. Effectively making the "True UPS" described above.
Won't work to protect the A/C (I have other stuff for that) but it sure protected the Microwave. - CA_TravelerExplorer III
cannesdo wrote:
The concern should be the thunderstorm not the inverter. Some RVers disconnect everything not wanting to chance possible significant electrical transients.
That said I never let the ATS or inverter switch with heavy loads. The heaver the load the more pitting that occurs on the relay contacts. Sometimes I'll switch from the gen/inverter which involves both the ATS and inverter relays with the TV on.
My dish doesn't move once set but the receiver could reboot if the changeover wasn't short. rv2go wrote:
I damaged mine when the shore power went off. Too big of a load on the inverter and it failed to trip off. Cost me several hundred dollars.
I now leave mine off when connected to shore power. The little inconvenience it may cause is cheaper than repairs or replacement.
1. Your Inverter is not installed to specifications
2. The "Load" if too much should not have harmed anything as the Inverter has Circuit Breakers that will trip from overload
3. The OUTPUT loads should be within the 30 amp power of the Inverter. See item 1. Doug- Triker33ExplorerMy Inverter has been turned on 24/7 for the last 14 years.
I have never unplugged from shore power during any lightning storm or other storms.
Even during one Hurricane. Of course after it went through there was no shore power :( I only lost both roof vents with Max covers, one window awning and broken patio awning roller.
That is what my $$$ surge protectors are for. To protect the MH.
Did I say I Full Time? - dahkotaExplorerWe unplug in lightning storms. Our inverter is always on, plugged in or not. We have had instances where campground power has gone out - we didn't notice.
